Supercharger belt
I just did mine on an XJR, I chose not to remove the hood (bonnet), but you do need to remove the fan assembly. There are two screws on top and an electrical connector on the bottom right (as you face the vehicle) side. It then slides up and out. You should have plenty of room at that point. I think that the XK8(R) even has more room in front of the radiator than the XJ series, so this should work just fine.
You could loosen the struts so the bonnet can be opened vertical, and it is out of the way. Then with a special tool (flat bar and a 1/2 socket that fits in the tensioner) you can take the tension of the belt to take it of. Then (bit fiddly) you can push the belt gently between the belt-tensioner & belt-idler from the FEAD. New belt reverse order ;-) Should be a 5 to 10 minute job.
Took me about 6 months of ownership before someone mentioned the 'service' position and how to get it up. And even longer to be told you don't have to remove the clip on that stupid bonnet strut to twist it off the ball-socket. The 2nd time I attempted this, the thing went into warp in my garage and has yet to be found.
(1) open the bonnet
(2) have two (2) 3/8" long bolts on you
(3) twist the top strut connection (where it attaches to the bonnet) so that it release the ball/socket (hold the bonnet, its heavy) lay down the strut into the engine bay
(4) move to the other side, remove the other top strut connection
(5) lift bonnet up vertical and align holes in the hinge so that you can insert a bolt on each side
(6) rest the bonnet on the inserted bolts and proceed to get better access to the front end
FEAD=Front End Accessory Belt.
Try to get the belt vertical in the place mentioned, and push it out from below (like in the picture). Then you get it past the bolt, and out it goes. New belt in is similar, get the belt vertical again, and push it downwards past the bolt of the idler. Takes a little time and patience, as the trick is to get the belt as vertical as possible, you will see what I mean.
![](http://i52.tinypic.com/21ooavt.jpg)
BeO (05-17-2011)
changed both belts few days ago, some info:
1) On my car (XKR, 4L V8 supercharged) it was impossible to completely remove the fan assembly. I released the bolts, as mentioned above, but I couldn't remove the thing. On the left side of the car there is a hose going into the radiator, on the right hand side there was an aluminum pipe (don't know, probably air conditioning).
2) I managed to finish the job anyways, just lifting the fan assembly as far as possible. then I was able to fit a normal ratchet into the square hole in the tensioner pulley.
3) I can confirm, it is not a big problem to remove and install both belts. You just need to twist them and get them in position trough the gap between the pulleys.
I did that, but the problem was on the top side. The small plastic pads on the sides of the fan assembly, the ones used to actually bolt the fan assembly to the radiator, there was the problem.
FS[MidWest]: 2001 Supercharged Vanden Plas
Col. Sandurz
09-28-2015 07:29 PM
