Trunk light
Old 12-28-2013, 11:32 AM
Don-T's Avatar
Default Trunk light
Okay, I feel dumb... Anyone know where the switch for the trunk lights lives? My lights come on randomly after the trunk is opened, sometimes not at all. What I thought was the switch, just to the right of the latch doesn't seem to move and I can't find anything else, help!
Old 12-28-2013, 12:19 PM
oyster's Avatar
Hi.
The light switch is within the latch.
Old 12-28-2013, 07:14 PM
Spurlee's Avatar
My trunk light has never worked properly. I'd say the operation is random except that at least sometimes you'd think it would come on at the right time and stay on. But nope.
It may be over engineered to only come on when it is dark out and not in the daytime, taking a reading from the headlight sensor. I'm not sure.
I gave up trying to figure it out.
Old 12-28-2013, 07:18 PM
avt007's Avatar
It's a microswitch built into the latch assembly. You could replace just the switch if you're handy.
Old 12-29-2013, 02:15 AM
keestanis's Avatar
I have the same issue; Micro switch is fine, but all the mechanics seem sticky, lubes dried out and dirty; Sometmes switches on after a couple of minutes; I applied lots of WD40, thought I had it cured and it came back within a fourtnight.
Gave up for the time being; Live's too short
Old 12-29-2013, 03:46 AM
avt007's Avatar
Oops, almost forgot- a common problem is the wiring harness where it goes up one of the hinge arms. They usually break there, causing intermittent lights or intermittent latch operation.
Common on BMWs, too.
Old 12-29-2013, 08:39 AM
Sambo21's Avatar
Here's a thread I started a while ago on this subject:
https://www.jaguarforums.com/forum/x...hts-out-86429/
Sam
PS After a year it's still working perfectly.
Don-T (12-30-2013)
mbergen
10-23-2019 10:26 PM
martybmw
04-02-2016 04:55 AM
XJsc-guy
11-23-2015 01:56 PM
prettydaim
09-07-2015 05:16 PM
02jagstype
09-04-2015 08:20 PM
Quick Reply: Trunk light
