Two rust spots to deal with
First attempt at painting a panel that can be seen for me.
I peeled the badge off after heating with a hair dryer, it took the paint of with it.
After a bit of scraping I could see the extent of the rust.
600 wet and dry got it to this, put some rust eater on the exposed part then sanded it back again.
A couple of coats of acid etch primer next.
Now I was thinking, I could do with some high build primer, but cart be bothered driving up to halfords to get some, big mistake. It looked ok at this stage with about 4 coats of standard halfors primer.
Flatted it back, and was thinking, "I think I will see the sanded part when I top coat, should have gone for the high build primer."
This is about 5 layers of topcoat, halfords made up spray can. The colur match is good but I should have featherd it more. The colour is consistent but the change in reflection gives it away.
Now when the badge is on it will not look so obvious, but I will need to fix it properly sometime.
Clearcoat will go on tomorrow.
Received 6,323 Likes
Better late than never, six years on I decided to fix the rust spot on the trunk lid. Previously I had just rubbed it down and put on a bit of epoxy primer as I knew I would have problems getting the chrome plinth off.
One of the four studs on the plinth was missing and the nuts on the other three were just spinning.
I managed to lever the plinth off and was left with this. The best deal I can find for a second hand unit is £70 so I will see if I can salvage this one.
All four of the plastic stud mounts were broken.
A few more rust spots to deal with.
After a bit of grinding and sanding.
Then some filler on the original problem area, it's the only part that needs to be finished carefully as the rest is hidden by the number plate.
I used a cut up part of a spray can lid to push the filler into the curve.
Then sanded it down.
Then some more primer.
Back to the plinth, I will make up 4 new flat head bolts to fit the remaining part of the mount, then pack out the upper part so there is not too much strain and hopefully it will bolt back on without too much of a problem.
RaceDiagnostics (05-02-2018)
RaceDiagnostics (05-04-2018)
Larry-Cleveland
09-25-2015 08:42 AM
shootingbrake
09-23-2015 10:54 AM
