Wiring diagram for Sat Nav display unit
Old 03-06-2015, 03:45 AM
dibbit's Avatar
Default Wiring diagram for Sat Nav display unit
Does anyone have the wiring diagram that shows the colours of the wiring that goes to the sat nav display unit in a 2001 XKR?
I have looked on the forum and can't find anything.
Old 03-06-2015, 05:00 AM
GGG is offline
Received 16,862 Likes on 12,186 Posts
It's in the 2001 Model Year XK8 Range Electrical Guide which is part of JTIS (Jaguar Technical Information System), available for download from General Tech Help.
To save you a lot of time - here's the one page you want!
XK8_2001_Navigation.pdf
The wires are standard Lucas colour code.
B = Black
G = Green
K = Pink
N = Brown
O = Orange
P = Purple
R = Red
S = Slate (Gray)
U = Blue
W = White
Y = Yellow
dibbit (03-06-2015)
Old 03-06-2015, 05:17 AM
jamdmyers's Avatar
here ya go
File Type: pdf
dibbit (03-06-2015)
Old 03-06-2015, 09:10 AM
dibbit's Avatar
Thanks guys, that is exactly what I needed. I have finally decided to replace the original sat nav unit with one that has maps of where I live (Spain) so I am replacing it with a Garmin. I need the wiring diagram to work out the connections for power, which look like:-
Switched 12v + White/Blue pin 4 (passenger side fuse box #16 5A)
Logic ground Black/pink pin 2
The Garmin is a very good fit for the existing plate, with only a very small amount of dremeling to make it go in. The screen isn't as wide as the original, but it's better than the outdated system.
Thanks again for the info.
Guy-Pierre Boucher
09-16-2015 05:55 PM
texaspete
09-10-2015 08:34 AM
danpop
XJ40 ( XJ81 )
09-08-2015 03:23 PM
Mike Green
09-07-2015 12:39 AM
pegasus3710
09-05-2015 09:40 AM
Quick Reply: Wiring diagram for Sat Nav display unit
