Worst tensioner condition without failure.
Old 09-16-2014, 08:20 PM
TheCounty's Avatar
Default Worst tensioner condition without failure.
Not sure if this is the worst tensioner ever removed that had yet to fail, but it is likely a contender. 1997 XK8 with 75,000 miles, just done.
Show us yours (failed, or broken of course are worse but how close can they come??)
TheCounty
Old 09-16-2014, 08:23 PM
DaveInVA's Avatar
Looks fine to me
Dave
Old 09-16-2014, 08:25 PM
cjd777's Avatar
Received 1,361 Likes on 752 Posts
WOW, It looks like you were one cold start from destruction. Way to go.
Wayne
Old 09-16-2014, 08:40 PM
Jag#4's Avatar
Man, you are lucky to have caught that when you did! I'd go buy a lottery ticket in case your luck is still with you.
Old 09-16-2014, 09:18 PM
jimmiejag's Avatar
Both of my secondary tensioners were split fully down the middle, too. The "shoe" from the bottom of each is apparently in the sump since each plastic "shoe" was missing. My 1999 XK8 coupe has 78,000 miles on her.
The most difficult of the zip-tie replacement for me is getting the gasket sealer cleaned off the heads!
Not to hijack this thread, but does anyone know of a solvent that will remove a rubberized gasket sealer? I have been scraping the heads with a screw driver but it's a long and tedious process.
(Sorry the pictures are so dark.)
Attached Thumbnails Worst tensioner condition without failure.-20140828_184838.jpg   Worst tensioner condition without failure.-20140828_184843.jpg
Old 09-17-2014, 02:20 AM
steeevo's Avatar
Wow we were lucky. Exactly the same as mine i did a few months ago.
I find the gaskets a problem aswell when rebuilding small engines, there is a solvent silicone remover you can get that is ised for removing silicone sealant but havnt tried it yet
jimmiejag (09-17-2014)
Old 09-17-2014, 11:35 AM
Chuck Schexnayder's Avatar
Now there's a real mechanic. Cleans up the old part to "look new" condition........well done.
Chuck
Old 09-17-2014, 02:39 PM
brgjag's Avatar
It's just a crack, put some filler in there and go with it.
Old 09-18-2014, 01:53 AM
bamforp's Avatar
1998 XK8 with 84k miles and no obvious noise or rattle coming from the engine.
Old 09-18-2014, 07:49 PM
stevepaa's Avatar
Mine looked similar, but with some pieces missing from the rails
Old 09-21-2014, 10:06 AM
reb1999's Avatar
Hi County, wow, all the discolor as well. Have not gotton to mine 99 XK8 yet. Next project. I plan to have a good Jag tech do the job.
I still believe hi under hood temps do not help the matter. I am a firm believer of synthetic oil. Does see, to help stabilize oil overheat and discoloration as well as changing often.
Tried an experiment, fabricated an air dam just behind the radiator under the car. Works well by forcing more air into the radiator and engine compartment, notably reduce engine temp. Problem, car is so low clearance is a problem. I will try something smaller next. Rich
picard
10-12-2015 11:56 AM
hoodun
10-02-2015 10:13 PM
Tim Goz
09-17-2015 09:11 AM
Dickie_L_J_O
09-13-2015 07:44 AM
davidladewig
09-11-2015 06:48 PM
Quick Reply: Worst tensioner condition without failure.
