An XK8 Project (1999MY)
I've decided to create a thread whereby I can update the progress on the restoration of my 1999 XK8. To date I have acquired;
1) All replacement suspension components including struts, mounts, rotors, calipers, all universals, stainless break lines, all bearings.
2) Water pump, aluminum thermostat housing, new thermostat, etc.
3) Tensioners', etc, etc. The motor was replaced under warranty with a second gen but I will change the tensioners out for third gen anyway.
4) Removing Transmission in the next week and then starting on a complete overhaul of the body.
I will continue to add pictures as the work progresses
Open to suggestions and comments and look forward to same. Have already picked up a ton of ideas including lamp upgrade that have led to the purchase of a number of goodies![Icon Dance Cpatch](https://www.jaguarforums.com/forum/images/smilies/icon_dance-cpatch.gif)
Thanks in advance.
Thanks in advance.
Last edited by GGG; 04-29-2014 at 01:19 PM. Reason: add Model Year to thread title
Rezzz (10-29-2014)
I would like to make a suggestion or two.
Would it be possible to give estimates for price and time for the work done, or even complexity? I would be very interested the amount and time needed for suspension and brakes, since I willl probably have to do the same at some point.
This has the potential for a sticky or reference for anyone interested in getting or fixing a XK8.
Please keep us up to date on your progress!!
My pleasure I am logging everything including parts cost and time and labour. My friend is a mechanic with over 25 years on foreign (meaning not from North America) cars and he will be doing the work with me. It is an after hours and weekend project. My other friend owns a body shop and that part of the work will be undertaken in a similar way.
JSC (04-29-2014)
very nice,love the red.i repainted my 99 coupe four years ago and toyed with the idea of red since the inside was black.but then decided the original outside color of black was the way to go.i was suprised to find out that jag did not offer bright red with black interior...steve.
FWIW, my 1999 Phoenix red coupe has a Cashmere interior. Both the exterior and trim are the OEM colors, according to the door jamb sticker.
I've not seen many Phoenix red coupes and don't recall ever seeing one with black trim (interior). It's apparently even more rare.
Parts List to Date
Brake pads front and rear
Parking brake pads and rebuild kit
New parking brake cables
Fuel pump
Fuel filter
New plugs
New slotted and drilled brake rotors
Brake caliper repair kit – two
Brake hardware kit – front two
Rear suspension stabilizer back end link kit
Rear shocks
Rear lowering springs Mina
Rear differential universal
Half shaft universals – full set
Half shaft spacers
Front shocks
Eccentric shank bolts
Rear wheel bearings and retaining rings
Tapper bearings rear
Front wheel bearings and retaining rings
Braided stainless brake lines
Entire radiator hose set
New thermostat
New thermostat housing aluminum
Coolant reservoir hose
New water pump
New octopus hose
Front hub spring clips
Shock mounts front and rear
Intake gasket set
Crank case hose
Breather intake hose
Fuel pump
Fuel filter
New plugs
Rear shocks
Half shaft spacers
Front shocks
New thermostat
New water pump
New octopus hose
Intake gasket set
Crank case hose
Your progress looks great as does the car. Its the same MY as mine so I am very interested in your posts. At this time I have just got over a problem with my car going into restricted performance mode and showing gearbox fault, it was the rotary switch. I still have it at the back of my mind I will have to switch out the autobox as occasionally the original one bumps a bit, of course it could be that it is still in learning mode, with new oil and filter I certainly hope so.
Your parts bill must be quite high now, hope you dont have to add much more to get the car back on the road. Good luck with the project.
Arty
Arty
Arty
Arty
Thanks Arty. To date my total cost in parts is $3918.78 US. The Transmission is going to be about $2200 US on its own. My budget for the project including new wheels tires, exhaust system, sound system, interior upgrade and refinish is $10,000.00 US
ArtyH (05-22-2014)
greenforest56 (12-23-2014)
