XK8 Security module wiring
Old 09-28-2013, 01:15 AM
dinks747's Avatar
Unhappy XK8 Security module wiring
Good day enthusiasts and guru's.
I have a 97 XK8 convertible, that the security module in the boot needs replacing due to water damage. I bought the car with this known problem.
I have bought another module, but there are 3 of the connecting wires that plug into the module via the harness, have pulled out of the harness end clip.
If anybody has any experience with this wiring order, or has pictures of a fully functional harness end clip, I would be most grateful for the help.
I have looked at the wiring diagram, but it is still not very cleat to me which wire goes where.
Short of buying an entirely new harness just for this small fix, any inputs would be much appreciated.
This is preventing me from getting the roof working (I believe the security module also controls this) the valet mode to release (stuck in valet mode) the reverse lights to work, and the boot open message to clear.
Many thanks in advance.
D
Attached Thumbnails XK8 Security module wiring-img_0389.jpg   XK8 Security module wiring-img_0390.jpg
Old 09-28-2013, 03:37 AM
GGG is offline
Received 16,860 Likes on 12,186 Posts
I've moved your question from General Tech Help to XK8/XKR forum. This is the place to post specific questions about your model.
The photo is the 16-Way BT40 connector to the SLCM?. Here is the pinout from the 1997 Range Electrical Guide:
The main colour / stripe for the pin numbers is:
1. OR = Orange/Red
2. OB = Orange/Black
3. UG = Blue/Green
4. GW = Green/White
5. YW = Yellow/White
6. NK = Brown/Pink
7. OG = Orange/Green
8. S = Slate (Gray)
9. GR = Green/Red
10. Not used
11. UO = Blue/Orange
12. Not used
13. BK = Black/Pink
14. BK = Black/Pink
15. NY = Brown/Yellow
16. U = Blue
Hope this helps.
gpollich (02-13-2015)
Old 09-28-2013, 04:27 AM
dinks747's Avatar
Many thanks Graham, this is perfect! At least now I can trace where all of these wires should go.
And hopefully put end to all the other associated woes.
Have a cool day.
Dion
Old 09-28-2013, 04:41 AM
dinks747's Avatar
Graham I forgot to ask where you got this info from? It would help me further in trouble shooting if the connections I remake are successful or not. I.E Knowing which wire powers which system, will eliminate redoing them all again as apposed to just the inop system.
Dion
Old 09-28-2013, 09:15 AM
Paul Pavlik's Avatar
Dion
The Electrical Guides can be downloaded from here:
Jaguar electrical reference
Old 09-28-2013, 01:08 PM
dinks747's Avatar
Thanks Paul, much appreciate it! That problem is now solved thanks to you gents, so I am for ever indebted to you.
I ended up cutting the harness end cap off and adding ends individually to each wire and then pressing them on in the right order. Not ideal, but it works!
My next issue now is that the roof will still not operate. I can hear the pump run, and the driver and passenger windows open slightly (like when opening the doors) but it then seems to time out and the windows close again.
It may be the fluid which seems ok, but I have not really checked it properly yet.
Other than that, all the other associated woes are sorted.
My thanks again, and hope I can return the favor some day. :-)
Dion
Old 09-29-2013, 12:55 AM
dinks747's Avatar
Default Security Module and roof resolved
Hi guys. Just a quick note of thanks.
This is a copy paste of what I posted in another old thread that I had used to troubleshoot my module and roof problems. Your help and assistance got me moving in the right direction, so please see below as my thanks to you again.
This thread really helped me get my roof sorted out as well. I bought a water damaged 97 convertible, with a damaged SLCM (security locking control module) So many thing didn't work. The roof being one. So after buying a second hand module off ebay, I had to modify the connectors due to the original ones being corroded. Got it connected up and it fixed all the small things (stuck in valet mode, no reverse lights, boot open warning) But the roof still did not work. I could hear the pump run, but nothing else happened. It was only after replacing the reverse light fuse that had since gone in all the wire work, that the roof worked perfectly! It was in the fully closed position, 1st press opened and worked as advertised. 2nd press closed and seated perfectly.
I am not sure if this is even related, but that is all I did and the roof worked after that. So if you are still battling with yours, it might be worth checking that 5A fuse in the boot fuse box.
Thanks to all for their posts here over the years, every little bit helped.
Safe roof down travels :-)
Dion
Old 09-29-2013, 02:52 AM
GGG is offline
Dion
Paul has already given you a link where you can download the Electrical Guide.
It's part of JTIS ( Jaguar Technical Information System - the Workshop Manuals) which you can download from the forum:
https://www.jaguarforums.com/forum/g...rchives-65926/
With the project you've taken on, JTIS will be a big help.
Old 09-29-2013, 04:24 AM
dinks747's Avatar
Everything all sorted thanks gents. I now have a fully functional 97 XK8 with only 16230 original miles on it to enjoy!
Next posts will be about the body conversion.
My thanks again to all who gave inputs and advise.
mrplow58
01-21-2024 05:53 AM
St.Regis
04-06-2021 12:34 AM
roby
09-20-2015 01:54 PM
YycXJS
09-07-2015 09:58 AM
jaguarbill
09-05-2015 11:43 AM
Quick Reply: XK8 Security module wiring
