*** FREE PRIZE giveaway X100 Remote Top Module ***
#81
Heyyy!!
Greate contest, kudos to WhiteXKR!
I want in aswell.
Would love to accecorize my 2002XKR with this neat feature aswell.
Keeping my fingers crossed.
Regards and good luck to you all.
/D
I want in aswell.
/D
#85
I've had similar issues. I'd first start with the grounding straps from the steering knuckle to the chassis and check ABS sensor is clean. The straps can break causing all sorts of havoc and are a pain to R&R as they are attached around the brake line. I would start there..from there its a mix-match between faulty ECU/ABS control units, which all had leaky capacitors, causing a bunch of hard to trace electronic gremlins. I had a huge range of codes, had the ECU rebuilt and it cleared everything - not until I replaced all the coils and a used ECU (which also failed).
