[DIY] Jaguar XK8 Alpine M-Bus AUX in/switch
Old 04-11-2019, 04:14 AM
dibbit's Avatar
Originally Posted by kainy
Yeah, I know this one, but he is not using the cd changer, which is my main point. I will still investigate how the phone bit works in more detail.
From the pdf:-
Now that I have this auxiliary audio input, I connected it to the stereo output wires of the T605 bluetooth kit. The T605 also has an
auxiliary input so you can pipe musing through it into the car stereo. If my CD-Changer still worked, I could connect the 3 wires from
the white connector (blue, green, and black) to another set of RCA jacks and then connected these to the T605 stereo input connector
(using the appropriate adapters). That would allow the CD-Changer to still work and have the bluetooth.
Old 04-11-2019, 06:17 AM
kainy's Avatar
Yes, I just read it. In short it just has the switch I am trying to make outside my bluetooth inside itself I am gonna check if newer version are available with similar function.
Old 04-11-2019, 03:04 PM
kainy's Avatar
Honda Wireless Bluetooth Streaming Handsfree Interface :: HONDA :: XCarLink
This is the closest I can find that is even locally available (not the example I am giving). However my local dealer didn't specify it as Honda unit, but is offering it as a universal solution. The nice thing is that their showroom is at walking distance from work, so I am going to check tomorrow if this is compatible. Looks like it covers all the basis - aux out, mute, aux in, steering wheel / radio control for both handsfree and bluetooth (seems a bit hard to believe thou). Fingers crossed
jagosaurus
03-11-2016 08:41 AM
vdpnyc
06-25-2015 08:52 AM
TallXJDriver
10-15-2013 05:20 PM
jagosaurus
09-24-2012 02:19 PM
amcdonal86
11-17-2010 11:05 PM
Quick Reply: [DIY] Jaguar XK8 Alpine M-Bus AUX in/switch
