[GGG] How-To (temp copy)
Test link
https://www.jaguarforums.com/forum/x...or-how-137620/
End Test Link
Additional test link - GGG
https://www.jaguarforums.com/forum/x...006-faq-67827/
End Test Link
'HOW TO'
Please find below links to 'HOW TO' subjects to date.
There may well be some missing that YOU think should be included OR have information that may supersede info below. In this case please contact either myself or one of the mods.
Links to subjects:
How to use the SEARCH function
I’m buying a used XK8/XKR, what should I look for?
Link 1 | Link 2
An XK8 Primer for the new owner:
Searching for a used/salvaged or reconditioned part (body, mechanical, wheels, etc) try this mega-database called Car-Part.com. I find it more vast than ebay, prices included on most items too.
![Icon Exclaim](https://www.jaguarforums.com/forum/images/smilies/icon_exclaim.gif)
- Would you like to run your JTIS CD on Windows 7 of Vista? Here are instructions on how to make it work.
Download a copy of the driver's manual, navigation or multimedia system, bluetooth and jaguar voice manuals, list of available accessories, and other model specific documents from Jaguar
Download the Jaguar XK Vehicle Care Manual; find out how to check fluids, change light bulbs, tow your car, change a tire, locate fuse boxes and individual fuses.
xk8/xkr_handbook_download_1997_2003 GGG
DOWNLOADS (Assorted Tech Guides)
Parts List and Diagrams for 1997-2005, Pages 1-10 (in pdf)
Parts List and Diagrams for 1997-2005, Pages 11-23 (in pdf)
More Parts Files (kindly supplied by hlgeorge)
XK8 Parts, locations and identification fiches. (in pdf format)
XK8 Parts, File 1
· Engine
· Engine Management/Emission Systems
· Air and Fuel Delivery Systems
· Engine Cooling Systems
· Exhaust System and Components
· Transmission and Driveline
· Steering and Suspension
· Braking System
· Air con/Heating/Ventilation
· Wiper and Washer Systems
XK8 Parts, File 2
· Electrical Distribution System
· Information Systems and Controls
· Battery/Starter Motor/Alternator
· In Car Entertainment
· Lighting- Exterior/Interior
· Locking/Security Systems/Horns
· Seating
· Occupant Restraints
· Interior Trim and Linings
XK8 Parts, File 3
· Exterior Fittings and Sunroof
· Body Closures and Sealing
· Body Metal Panels and Sealing
· Accessories/Consumables/Index
AJV8 Engine and 5HP24 Technical Information (in pdf) from Jaguar August 1996
XK, XJ and S-type (2001 MY - technical information) in pdf, from Jaguar August 2000
Pages 1-60 Introduction to the 1997 MY XK8, in pdf, from Jaguar August 1996
Pages 61-122 Introduction to the 1997 MY XK8, in pdf, from Jaguar August 1996
XK and XJ 1999 MY Update - technical information, in pdf, from Jaguar July 1998
2003 MY Technical Service Guide and an introduction to the new features (a good read!), in pdf
Vehicle Specifications
^ ^ for the XK8/R, S-type, X-type and XJ; includes VIN identification, bank/cylinder ID, torque specs, alignment specs (if they haven't been superseded by new ones - check with dealer), spark plug and all fluids specs, and a ton of other good information
Thanks to Dan at Nalley Jaguar, we now have an XK Accessory catalog for the XK8/R. Many of these can still be ordered, just ask them.
Would you like to know how Jaguars WDS/IDS/SDD diagnostic computer system works? You're questions answered, they will be.
Driving Cycle Instructions, by Ford...but hey, maybe it applies?!
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
![Icon Dance Twist](https://www.jaguarforums.com/forum/images/smilies/icon_dance-twist.gif)
Link 1 | Link 2
Topics in Alphabetical Order A-M
ABS / Traction Control
. Cleaning the wheel speed sensors to clear an intermittent DSC fault.
. Reparing the ABS module using a little soldering skill to correct another intermittent DSC/Traction Control fault. If you have a 1997 or 1998, please read this thread before you start cutting apart your ABS module.
. Very thorough diagnosis of ABS module failure
. Another Link
Air Bag (Secondary Restraint System)
. Air Bag 'Flashing' Codes straight from a Jaguar TSB (in pdf)
. Driver's Air Bag Light Blinking 2-2 - DIY diagnosis
https://www.jaguarforums.com/forum/at...1&d=1357809011 Airbag codes and checks, thanks to Azeteg
Air Conditioning
. Link 1 with ambient temperature chart
. A/C Error Codes and Repair/Troubleshooting guide from the JTIS
Alignment issues
. Link 1
Antenna
. Disconnecting / Remote Switch Install
. Replacement & Repair
Audio Upgrades
. Link 1 | Link 2
. Fascia Adapter parts required from Jaguar for a single-DIN aftermarket stereo
. Subwoofer addition to rear 'seat'
. I-phone integration, including video out to the NAV screen (HDMI), bluetooth streaming and phone - all with the factory head unit!
Battery and/or Charging System
'Hard Reset' and procedure after battery disconnect. Thanks to Steveinfrance, Graham, Derek & Red1bw
. Dead battery and can't open the boot to jump start?
Quote:
Originally Posted by Paul Pavlik
![](https://www.jaguarforums.com/forum/images/kirsch/buttons/viewpost.gif)
These terminals can be used to charge the Battery or power the car so that the trunk can be opened with the button on the dash.
They can NOT be used to start the Car.
Bluetooth & Auxilliary Input Additions
. Bluetooth to Jag Wiring & an auxiliary input
See also "Audio" above
Brakes
. Bleeding the brakes
. Brake pad options, XK8 & Rs #1
. Brake pad options, XK8 & Rs #2
. Brake pad and rotor replacement Step-by-Step Guide (on an XJ8, but all still applies to the XK8)
. Brake switch replacement (write up c/w pics )
. Brake rotor specifications, regular and Brembos, N/A and S/C, with minimum thickness and runout data
Car won't start? - read this first (see 'Engine' Section below also)
> Car won't start
Check Engine / CEL Codes
. Cruise Control Unavailable
... Restricted Performance
See Transmission below
P0351, P0354, P0356, P0357, and P1367 - ECM leaking capacitor leads to CEL and Restricted Performance faults: TSB 303-49 Restricted Performance.pdf
Climate control
. Error Codes translated
. Heater vents sticking
. Climate Control Module rebuilding companies
. A How-To article on retrofitting the OEM cabin air filter housing into the car (RHD car instructions w/ lots of pictures!) Also shows you how to remove your wiper arms.
Color Codes (paint)
. Exterior
Convertible Top Latch Hydraulic Leaks
. Have you received a green shower? Does your top groan and fail to open and/or close. Fixes, parts, pics and advice a-plenty here in this thread.
. (Option 1)
- Hydraulic Line Evaluation and 'custom' pressure reducing valve
- Alternative relief valve option thanks to Steveinfrance
- Hydraulic pump voltage reduction using a resistor (the long, debated version)
- Condensed, and organized version authored by Dennis07
- Install Video of the Resistor, by Reverend Sam
how to top up your diff oil
Coolant System (Expansion Tank, radiator, hoses, thermostat, etc)
. Coolant testing method to determine performance
. Replacing a leaking thermostat tower
. Different types of coolant for different model years - a good discussion of the differences and why the change
Engine (General)
. Cylinder Wash - is this your problem? Did you run your engine for just few seconds or a minute, and now it won't start?
Detailed Procedures for Starting an Engine that ran for a moment and now won't start. (thanks Gus).
. Noises Observed at Startup (usually cold)
. Leaking Engine Mounts
. Want to replace an engine mount yourself? Instructions are in this thread.
. Engine Control Module rebuilding companies
. Swapping a 4.0L with a 4.2L Success
. Can a supercharged engine be installed into a normal aspirated car? (applies to S-type R, XKR, and XJR)
. Cleaning the Throttle Body, MAFS & Part Load Breather DIY instructions(from another good site - maxperformancecars.com)
. Jaguar's recommended maintenance schedule and detailed TSB for full load breather cleaning
. How to change spark plugs (with video)
. Understanding Fuel Trims
. Oil in the airbox - might be an easier fix than you think FAQ Thanks to The Coupe
Supercharger removal Thanks to Mawwdg
Cylinder Identification - this might help
...Tensioners
Quote:
Originally Posted by test point
The engine serial number encodes the date the engine came off the engine assembly line. The conversion to metal tensioners occurred on August 13, 2001, thus a serial number of 010813xxxx (YYMMDDHHMM). There is no direct correlation between the engine serial number (date of engine assembly) and the VIN although a dealer can provide the engine number from the VIN.
Link 1| Link 2 | Link 3
. Primary and secondary tensioner repalcement Thanks to Matt (H20boy)
. Story of secondary tensioner failure and broken timing chain] (XJ section, but same 4.0 engine)]
Secondary tensioner change Zip Tie Method EZDriver
Electrical
. Find your Electrical Diagrams and Information (All Model Years - even other models)
. Brake Lights intermittent function - caused by a melted ground (good news, there's a fix here!)
. Check ECM ground via OBD port
.Instrument lights not turning on check this thanks to: or_blk_XKR
EVAP
. How the onboard EVAP test works -with thanks to ccfulton
Exterior / Mechanical Issues
. Door Handle Removal & Gasket Trim Kit replacement
. How to replace the XK8 grille and overriders with the XKR mesh
. Replacing an early MY boot plinth (trunk finisher) with a newer version and adding a release button (authored by XKRacer, and soon to be a New York Times bestseller)
Exterior / Cosmetic Issues
. How to touchup the paint on the 'grey' window molding (waist rail)
. Removal and replacement of the bonnet badge
Removing the rear parking sensor, thanks to Tony and Frog
Rear bumper parking sensor - how to remove?
Factory Phone
. Link 1
Fuses / Battery / Power Issues
. Fuse chart for 2002
Gasoline & Fuel - Octane requirements
. Octane requirements discussion
Headlamps (HID and Halogen)
. Moisture / Condensation in Housing
. TSB 417-05 (install a vent)
Heater Pump Removal (thanks to RaceDiagnostics)
Heater Pump Removal - "How To"
[url=http://matt.zenfolio.com/2010-03-28_012930_1997-2004_xk_headlight_vents.pdf]
HID / Xenon Ballast
Quote:
The ballast is made by Valeo, and ballasts are not designed to last forever, so they will eventually "burn out." When this time comes,this Valeo (12 pin) LAD5G ballast is used in several other cars by several other car companies. After researching them all, this ballast is sold cheapest by Chrysler / Jeep / Dodge - part# is 68019173AA in the $230 price range.
The ballast is found by removing the headlamp, turning it upside down, then replacing the old one.
Interior / Mechanical Issues
. Defroster / Demister rattle repair procedure (with lots of pics)
. Door Panel Removal (Door Card)
. Adjustment of Window using the regulator stop, with video
. DIY Visor Repair (to correct 'the flopsies', no tape required!) with Video
. HomeLink Garage Door Unit - compatibility issues discussed
. DIY Cup Holder Repair
. Emergency boot access - key locked in boot
. Tilt/Reach Steering wheel Motor #1
. Tilt/Reach Steering Wheel Motor #2 (on an XJ, but still applicable)
. Here's a possible DIY fix thread
. Popping Door Hinges?
. Rear Window Regulator Removal and Replacement
. Seat Headrest
. Another Headrest Fix Thanks to Mike R
[url=http://matt.zenfolio.com/xk-headrest-tsb.pdf]
Want a simple video instead of all this reading? The Reverend Sam has you covered - go here
. Door Latch Removal - Window drop and return promptly upon release? Is the door always 'open' according to your car? Door latch is at fault, and here's another Reverend Sam video to show you how to get it out...then you're on your own. j/k
. Replacement of the micro switches in the Door Latch - DIY instructions provided
Interior / Electrical Issues
. DIY Bulb Replacement #1 (gauges, cluster, and other names) PDF with pics of the process
. DIY Bulb Replacement #2 (gauges, cluster, and other names)
. DIY Bulb Replacment Video
. Seat Operation
. Seat Memory
. Trunk Lights inoperable due to failed micro switch
Mass Air Flow Sensor (MAFS)
Discussion of Cleaning Link 1 | Link 2
. Here's the DIY instructions (from another good site - maxperformancecars.com)
Mirror (rear view) replacement & repair
. Link 1
More Topics in Next Post
