01 jaguar xkr convertible
Look at your relays. When you check voltage at the leads to the pump the White is the down feed with the Black as ground and the Black is the up feed with the White as the ground and both are ground when not solicited.
The 40a fuse provides power to pin location #5 at the up and down relay but not to the pump white and black leads until the relay is told to do so.
Oneline for your car http://jagrepair.com/images/AutoRepa.../jagxk2001.pdf Figure 15.2
Is your latch opening? You need to check your fluid level and at the same time check the petcock closed on the side of the pump.
moonpetal38 (03-17-2012)
If the relay is not the problem then I would suggest recycling the roof operation. Manual roof operation JagRepair.com - Jaguar Repair Information Resource Once you get the roof open then close the petcock and close the roof electrically.
