01 Jaguar XKR no spark! Help
I am a great technician but this thing has me beat down!!! NO SPARK!!! I have checked the crank signal changed out two known good sensors and have a crank signal, I have fuel pressure, power at injectors and coils. Resistance tested the wires from coils to ECU all good! replaced ECU still no spark! No codes PLEASE HELP!!!! Is there something I am missing here, what does the security system disable????
The linear switch on the side of the shifter was flickering when the P or D or N was illuminated it was cleaned and it does not flicker anymore but still does not start i'm going to try to bypass it . the neutral safety switch thats on the transmission I do not see anywhere, the xkr has a mercedes tranny any help where that is located would be great, I have never been so stumped in my life,
this is what i can not find
New Jaguar Vanden Plas XJ8 XJR XK8 XKR Neutral Safety Switch Genuine LJA 6201AD | eBay
You may want to shift through this:
Mercedes-Benz 722.6 Transmission FAQ - Mercedes-Benz Forum
Comparing the jtis to the ZF to the 722.6 while the ZF has a service on the range/neutral switch the 722.6 does not, so the implementation is different, I believe it may get the signal through the duel linear switch to the tcm.
trosty
08-05-2016 03:59 AM
Michael Wittmann
03-29-2016 05:16 PM
Michael Wittmann
03-27-2016 07:45 PM
