'01 XKR Steering Wheel Airbag Removal
How do you remove the two wire connectors from the steering wheel airbag? I have the airbag loose, but want to make sure that I remove the wires correctly. I believe you squeeze the plastic tab on both sides, but then do they pull straight out (up) or ?
Thanks in advance,
Jim
Thanks in advance,
Jim
sorry, can't help you. There will be only a few who can confidently answer your question, probably a tech or someone very familiar with these air bag systems. My airbag was loose and I didn't dare do anything myself, so took it to the dealer to be corrected.
Bump for someone else to see this and hopefully get you squared away.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
Beardy
09-18-2015 10:00 AM
