01 xkr window issues
Hi,
Noticed another issue with my GreenHulk while waiting for valve cover gaskets to arrive: every time i touch the driver side handle window goes down about an inch or so. Car has been sitting about 2-3 months now while i am trying to fix the misfiring problems..Its pain in the butt...
Any ideas why this window keeps dropping?
Thanks,
Thanks,
This is usually a sign of reduced voltage or if the battery has been disconnected. You simply need to reset the windows. Put the window all the way down and hold the switch down until you hear an almost inaudible click. Then put the window all the way up and again hold the switch until you hear an almost inaudible click. Voilą, fixed. You will probably have to do this to the passenger side window also.
Green01xkr (03-31-2012)
There you go - I've learned something as well.
Thinking about it last night I was a**e backwards - if it's the microswitch the window doesn't lower when you open the door so you can't shut the door 'cos the window bangs into the door seal.
Glad I didn't take a bet on it - and glad it's fixed.
99xk8guy
06-05-2023 06:28 AM
