02 XKR Seat Fire
I am not aware of any fluid in the seat, I've had mine apart a few times, for lumbar and headrest repairs. My guess is someone spilled something or it could be the top fluid, if that is the case there would probably be evidence of it elsewhere. Usually the console gets drenched so check out the trans tunnel underneath the gear surround and trim. - I do not know if the car is RHD or LHD but the hoses are routed from the latch down the left A-pillar and down the left side of the trans tunnel then the cross the trans tunnel at the front of the back seat (all references are as seated in the car) So if it is a LHD car it would be unlikely that the passenger seat gets drenched, but you never know, and I am certainly not an expert on hydraulics or fluid dynamics.
I'm sorry, that was a thoughtless remark. I have worked on these modules. Everything about them is low current, and they are protected by a fuse. I can't imagine a fire there. Do you have seat heaters? Do you think that was the problem? Was the car setting unused when the fire started? Tell us more.
