03 Xk8 how hard is intake removal?
Old 10-30-2014, 03:39 PM
brgjag's Avatar
Well InjectorRx has my fuel rail and injectors. Hope to see them back early next week.
I should get in my remaining hose from EGR to TB and with that all I need to do before I get the rails back it torque down the intake bolts.
  #42
Old 11-06-2014, 06:33 PM
brgjag's Avatar
Here is my fuel rail, note the capped Pulsation Dampener.
  #43
Old 11-08-2014, 11:32 AM
brgjag's Avatar
well everything is in and ran the car for a good 20 minutes thus far and no freakishness from the car in warning lights or anything. Hopefully this is DONE.
  #44
Old 07-21-2015, 02:54 PM
sdbill's Avatar
Smile Valley Heater Hoses/ Intake Manifold R&R
Finally bit the bullet and went after the valley heater return hose. Knew from the condition of the supply/feed hose replaced a few months ago that it was probably on last legs. Got to it just in time, as the diameter had doubled, the wall grown paper-thin and about to "give birth". Once you have 100k miles on your car, replacing these hoses (and the surrounding other heater/throttlebody connecting hoses) should be a must. Removing the intake manifold is not difficult, just tedious, as other members have discussed. A step-by-step is included in the shop manual and is relatively thorough, except for the fuel line/fuel rail disconnect. Thanks to the other members in this thread for their insights.
Only real problems were the EGR tube screws that attach to the throttlebody ( a small one-by-two block of wood under the ratchet solved this one) and the fuel line disconnect. I could not get the plastic disconnect tools to work. The collar on the simple plastic wrap-around was too thin to fully expand/clear the locking spring, and the plastic clamshell collars did not penetrate the opening deeply enough to get to the spring. The answer was the anodized aluminum, hinged, swing-arm tool. The five-eighths size (green one) was a perfect fit, as it immediately fully expanded the spring and released the interconnect. It is available singly and in a set of four at most all parts stores and internet outlets. Maybe if I pulled hard enough, the plastic tools would have worked, but the receiver on the fuel rail looks to have minimum strength/ no margin for abuse.
  #45
Old 07-21-2015, 09:04 PM
brgjag's Avatar
did you take off just the black plenum or also the metal intake part under it also? If so did you replace all the rubber and metal gaskets?
  #46
Old 07-22-2015, 06:36 PM
sdbill's Avatar
Default Intake Manifold R&R
The 4.2L engine is simpler as to seals: the plastic manifold and aluminum fuel injector ports are all one piece, and there is just one seal per cylinder bank. Too bad I could not remove just the plastic manifold.
  #47
Old 07-23-2015, 02:41 PM
brgjag's Avatar
The black plastic intake to the aluminum injector ports have 8 indvl rubber seals that should be replaced if you take the two parts apart. i was told not to reuse the rubber seals. Jag does not sell those, you have to buy the complete black plastic intake with them in it. I got my seals from the same motor setup on a landrover/rangrover motor.
If you don't break these parts then yes there is one metal gasket per side.
99xk8guy
05-28-2024 09:36 PM
Kevin Burnaby
06-28-2020 08:04 AM
dsnyder586
04-04-2019 02:38 PM
cissdm
05-03-2016 06:02 AM
Saturbo
09-08-2015 07:35 PM
Quick Reply: 03 Xk8 how hard is intake removal?
