04 xkr seat reclines back, but will not go up
My new to me 04 XKR, has a problem with the seat recline system. The drivers side seat will recline, however it will not go back up when the button is pushed, Per other threads I have read, I swapped the seat modules, how ever that did not work. Now I am stuck with the seat to far back to drive safely. Any ideas as to how I can get it back up? If you know a trick please let me know. Thanks!
How is the seat heater function? Does it work? Does the light come on?
Normally, in nearly all cases, the modules need to be fixed. The circuit board moves against the hard plastic shell, and the outside edge tracks break off. The easy fix (for someone with soldering skills) is to bypass these tracks with individual wires. I am saying you possibly have 2 "bad" modules.
If you check on jagrepair.com, you can find the complete wiring diagram (the '03 book applies to you). There are diagrams for the seat controls on Fig 12, as well as the control modules, including wire color. If you are comfortable, applying the right voltage at the harness under the seat will drive the motor directly. Obviously, that would be outside of any range check, and, unless manually added, without the protection of the fuse.
Best of luck, keep us posted.
When I swapped the seat modules, the passenger side continued to work 100%. And the drivers side recline still does not. The seat heater works perfectly fine, dash buttons illuminate and work as they should.I then swapped the seat button module, along with swapping back the control modules, to try every configuration. The passenger side functions 100% in every combo I used. I was unable to get the drivers side to recline in to the up position.
I will be pulling the seat to manually power the recline motor, this weekend. I will keep you guys updated.
