05 Xk8: rear bushings?
Lower shock bushings are prone as well. If you have a friend bounce the rear of the car and you put you finger on various joints you can often identify where the problem is coming from.
If you have CATS then it could be the valving inside the shock. No fix for this but to replace the shock unfortunately.
The lower control arms are bearings. They can stand some cleaning and relube, but there isn't much there to cause noise.
As stated above, the upper shock mount is the most likely source of noise. The upper shock is located by foam donuts and the large top washer can hit the top of the upper shock mount if the top donut crumbles.
For non CATS cars, new bilsteins come with boots and all the donuts required and fix both the upper and lower sources of a rattling noise... for about $110/each.
zidjan (07-13-2016)
