05 XKR A/C Compressor Source -HELP
I desperately need help finding a 2005 XKR A/C compressor, reman, new or if no luck, used.
FourSeasons(94731) and Murray have the wrong compressor in their listings and such, therefore , all their distributors also have the wrong one.
Our XKR has a 6 Rib main Serpentine. Every replacement compressor we find is a 7 rib. Does anyone have any help they can offer? Or am I SOL and will just have to run the 7 rib?
Car has been down since June 29th and feels like there's no end to this.
For those of you at Colorado Concours, you know our story.
Have you tried a discount Jag dealer?
JPAM Parts
http://www.jpamporschejaguarparts.com
Phone number:
7200 W. Sahara Ave
Las Vegas, NV 89117
Supposedly part number: c2n2663
Here is the linkto the part: Jaguar Parts - Direct JPLV Porsche Parts.com
You definitely should call and make sure this is the right one before ordering.
JPAM Parts
Phone number:
7200 W. Sahara Ave
Las Vegas, NV 89117
Frustrating update
The clutch was burned out so bad we couldn't resurface/rebuild it. A special thanks to 4Seasons for all their help and research.
Jaguar sent out the wrong design spec to all the re-manufactures for the 4.2 XKR A/C compressor. ALL listings and part reference charts are incorrect for the 6 rib main serpentine on the Supercharged set ups. Other than new units from Jag, there are no 6 rib reconditioned units available. So you have two options, buy new or run a 97342 7-rib. Not what I would prefer, but I'm going with the 7 rib because $230 beats $1600. The body's are identical, its only the Clutch/Pulley that will be one rib to long. I will snap a pic of the setup once I get the car back together. Ported/polished supercharger and inlet in the meantime. Hopefully it makes up for the car being down for a month.
Dicque
09-19-2015 12:53 PM
