05' xkr squeaky brakes.. kinda sick of it..
Old 09-28-2019, 12:52 AM
avos's Avatar
Received 1,067 Likes on 761 Posts
Originally Posted by alexander thegreat
Nope, it's from the rear (my apologies if I said front before). The pictures are also rears.
Thanks.
I would change the rotors you are over the wear mark. Maybe because the pads are now enclosed from the sides (they float now in a bed due to the rotor wear), it could increase the vibrations causing the squeal sound. Either use then new pads or make sure they are flat again by sanding them.
I have had good experience with the Hawk ceramic ones when it comes to no squeal. Just make sure you do the brake job properly as fmertz says don't be shy with grease.
Old 09-28-2019, 04:05 AM
frankc's Avatar
I too had a nasty 'squeal' on my discs. After my local garage took a look it was soon fixed. This is a note at the time the job was done. May give you an alternative idea of what could be wrong. Dust shields? Have a read Click Me To Read
Good luck!
jagxkrtoofast
10-03-2017 09:36 AM
quaker13
04-29-2013 01:22 PM
91stealthes
08-24-2011 08:53 AM
newuser
10-18-2010 05:38 PM
dubydogg
12-02-2006 04:13 PM
Quick Reply: 05' xkr squeaky brakes.. kinda sick of it..
