'06 XK8- How Serious is Low Coolant Level Warning?
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I've driven my used '06 XK8 a bit over 10K miles with no coolant warnings and no pooled coolant underneath. On occasion I *have* smelled coolant briefly when the ventilation begins.
Since then I have had two separate Low Coolant Level warnings accompanied by a red status lamp. Luckily I've been close to home and topped off the cooled engine, requiring about a pint each time to fill the reservoir.
Is there some place I should be inspecting for leaks? Can I continue driving a longish distance after the warning if the temperature gauge doesn't show a rise?
Thanks!
DrOrb
Thanks!
DrOrb
Received 2,265 Likes
Received 4,323 Likes
if you smell it but have no visible puddles under the car - most likely the valley hoses or the octopus hose leaking. The valley hoses sit on the engine block under the manifold and the octopus hose is along the rear of the engine compartment above the catalytic converters.
As Mikey said - top off daily and only drive short distances but get fixed ASAP. As for driving a longish distance with the warning - NO!!!!!! By the time the temperature gauge indicates an overheat, it is TOO Late.
Recommend adding JagWrangler's Real Gauge upgrade to give true temperature or use a code reader capable of monitoring temp.
Also, the way the temperature sensor is placed high up on the engine, once you are down a moderate amount of coolant, the sensor will sit in air instead of fluid and you can fatally overheat the engine with no indication whatsoever (except low coolant) until the engine just stalls out, never to run again. This is one of the most common modes of engine failure on this V8.
The following 3 users liked this post by WhiteXKR:
About this time last year the thermostat housing in my wife's 2006 XK8 began leaking very slightly. I confirmed it with a pressure test kit I borrowed from Advance Auto Parts. I took the advice of several very experienced owners here and replaced the entire black plastic coolant duct assembly with a new one. Problem solved....
DrOrb (11-06-2015)
Find the source of the leak and fix it before it causes some very expensive issues.
