"06 XK8 Tape back won't play or reject tape
Received 2,434 Likes
Broken drive belt, tape wrapped around the capstan, dead motor?
If it won't eject, you'll have to remove the unit & dismantle it to find out what's wrong, unless you can very gently prise the tape casing out. It may well do the same thing to the next tape you try, though, without further investigation...
I fired up mine recently for the first time in at least 17 years and was somewhat surprised that it worked fine.
Them valves (tubes?) sound so much better than this modern solid state stuff
