07 XK front end on a 2001 Coupe?
Guest
Posts: n/a
Hi,
I am repairing a 2001 XK8 Coupe that was hit in the front end.
Since I"m going to have to buy new fenders, hood, etc, I was wondering if I could give the car a facelift by using front end components for an '07.
Any chance in *ell this could be made to work? I really like the new design.
RE: 07 XK front end on a 2001 Coupe?
With money, anything is possible. Nissan guys do this quite often with a mix of skylines and silvia's. I personally like the mixture in certain cars, but in others the lines don't flow well at all. You would have to see if the front wheel base's are of equal length or at least very close in proximity, and other than that...I don't think there is that big of a difference. Just keep in mind that you'll have to weld the radiator support from the 07 on the 01, and some other easier things such as rewiring the headlights, turn signals, fog lights(if equipped), and things like that. I don't think it would be too difficult if you have some fabrication skills.
Every jaguar owner I know likes everything about the new coupe EXCEPT the front end (which has been compared to a 4th gen. Ford Taurus). Interesting that you like it better than the old one.
Anyway, you should think about using a front end from a 2006 XKR instead...that's what I would do.
Guest
Posts: n/a
Someone thinks it looks like a Ford Taurus? Are we talking about the same car?
To me, the new Xk front end look a lot like the Aston Martin Vanquish.
Actually - and this willanger some of you - I was considering a kit that is made to make the older XK series look like the Aston Martin ( see www. carkitinc.com, ASH MART KIT). But I also suspect this guy is a scam because he wouldn't return my calls when I said I wanted to pick up the kit in person.
In any case, I like the XK coupes, but they are starting to look dated imo.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
Beardy
09-18-2015 10:00 AM
