1/4 window regulator 99 xk8 conv
Old 07-11-2014, 11:43 AM
wolfpck1's Avatar
Default 1/4 window regulator 99 xk8 conv
just replaced my regulator today couple of things ill add to the instructions mentioned in previous threads. {http://www.jagrepair.com/images/Auto...lacement-2.pdf} . have a magnetic pick up tool your gonna need it for the nuts and screws you'll drop in the frame . when removing the old unit remove the motor first if its not covered in plastic makes removing the frame of the regulator much easier . i havnt seen just the motor available so install the new unit rather than trying to swap motors . when installing the motor will just clear if you go in between the convertible top and the window frame . the front upper mounting bolt tends to be in the way trying to slide it forward into position remove it and you can put it back in thru a hole in the frame just behind the mounting area for the top bolt . then slide it forward into position.
The following 3 users liked this post by wolfpck1:
cooldood (06-05-2024), RJ237 (07-11-2014), test point (07-11-2014)
99xk8guy
05-28-2024 09:36 PM
99xk8guy
06-05-2023 06:28 AM
toronadomike
08-07-2022 03:41 PM
GordoCatCar
01-02-2017 01:10 PM
picard
09-19-2015 08:13 PM
Quick Reply: 1/4 window regulator 99 xk8 conv
