1997 Jaguar xk8 both tail light assemblies went out
Can you pull off the panels and look-see the housing and harness? Follow the wiring harness to where you see one or two wire end connectors attached by screws to the body structure. You should be at the end of the harness back there so the number(s) of wires will be limited. gordo
BrentGardner
28
04-26-2024 03:08 AM
