1997 xk8
1997 xk8
car has 64000 miles, and just had timing chain, water pump etc. replaced. its like the car has a ghost. the warning gauges, like bulb in rear out, when they are all working. also, when car is driven for over 10 miles, the temp gauge flutters, then drops into the red at idle. temp stays the same, and the tach stays at 700 rpms. does a computer need to be re booted, or something?
mike mitchell (03-26-2012)
Tail light holder ***'y has ground wire deficiency. There's probably a post or two here with pictures to show how to add/repair a proper ground. Pretty typical for a lot of european cars.
Temp gauge sender wire may be loose at the sending unit.
Tach - I've seen several, myself included, mention the instrument panel connector loose/needed reseating.
mikiep
12-20-2019 07:37 PM
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
