1997 XK8 - been stored for three years
Welcome to the forum Stephen,
(I've moved your post to its own thread. You'd posted on the end of a year old thread which could get overlooked.)
Sleeping cats need to be woken up carefully. Plenty of advice in the 'HOW TO' at the top of these threads.
Please visit New Member Area - Intro a MUST to introduce yourself and your XK8 to all the members. You'll also get some good advice there on making posts.![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
DewzeeXK8 (09-11-2012)
Assuming you have not started it up yet, it might br a good precautun to remove the fuel injection relay, and crank the engine for a few seconds to bring up the oil pressure prior to starting.
After 3 years, the chain tensioners may have lost their hydraulic pressure, which could cause the chain to slip with bad consequences.
Hi
If its been parked for three years and it was mine. id do what was suggested above(remove fuel relay and prime the parts including tensioners) prior to starting the car.
then prior to driving the car i would remove cam covers and change the tensioners, they may well be very fragile by now.
id check the engine oil, and check coolant pipes, and change the thermostat. all these items are critical items that could fail and cause damage.
then id consider doing the transmission oil, and give the brakes a once over.
Best Wishes
stephen
Best Wishes
stephen
Order tensioners from a Ford dealer, same parts, half the cost. I used sunroadfordparts.com
Order the parts for a 2001 Lincoln LS 3.9L
2W9Z6K254BA
2W9Z6K254CA
You will also need the 4 shorter bolts: W500301S300.
For a 97 you will need a AJ26 gasket set, which has to be a Jag part. There a a number of online sources, including ebay and various sponsers of the forum.
RJ_____________
97 XK8 86K mi
2W9Z6K254BA
2W9Z6K254CA
RJ_____________
97 XK8 86K mi
I am trying to bring a car back to life that has been stored for 20 years. Everything needs work, especially the electrical connections. Found problems everywhere. For example, one brake line would not bleed. What could clog up a closed brake line?
Three years is a lot less but expect to uncover issues for some time to come.
If you haven't read all the horror stories about tensioners please take a few minutes and understand the issue. The penalty of tensioner failure is too much to ignore.
. . . and welcome to the forum!
2W9Z6K254BA
2W9Z6K254CA
RJ_____________
97 XK8 86K mi
2W9Z6K254BA
2W9Z6K254CA
RJ_____________
97 XK8 86K mi
If you do a search for secondary timing chain tensioner replacement you will find lots of information.I will attempt copying one example below. Click on it.
https://www.jaguarforums.com/forum/x...ics-how-52653/
The process is fairly easy, even for those with limited mechanical ability.
If anyone can change a user name it will only be Jim as Admin.
Wolfy
05-28-2024 08:06 AM
99xk8guy
06-05-2023 06:28 AM
FS[SouthEast]: Rain X waterproof car cover NEW
Sublyminal
09-03-2015 04:48 PM
