1997 XK8 Code P0153
Old 07-19-2012 | 12:45 PM
Rip Reed's Avatar
Default 1997 XK8 Code P0153
what does code po153 on a 1997 jaguar xk8 thanks
Last edited by GGG; 07-19-2012 at 06:57 PM. Reason: edit typo in thread title so it appears in searches
Old 07-19-2012 | 03:46 PM
MRomanik's Avatar
Here you are:
P0153 :HO2S sense circuit slow response – B bank, upstream
Monitoring conditions:
Engine at normal operating temperature; a drivet 50 – 62 mph
engine speed 1500 – 2500 rpm>10 seconds
Default Action:
When CK ENG MIL is activated (DTC flagged; second trip),
ECM:
– Inhibits B bank closed loop fuel metering
– Inhibits B bank adaptive fuel metering
Possible causes:
Engine misfire
HO2S disconnected
HO2S mechanical damage
HO2S to ECM wiring intermittent open circuit
HO2S sensing circuit short circuit to high voltage
HO2S short circuit to ground
HO2S ground (BRD – braided shield) open circuit
HO2S heater circuit fault
Exhaust leak
Low exhaust temperature
Injector flow partially blocked
Catalyst efficiency decrease
HO2S failure
Rip Reed (07-20-2012)
toronadomike
08-07-2022 04:41 PM
DevonDavid
10-27-2021 08:19 PM
42Ajd
12-30-2015 10:45 AM
speacock
09-14-2015 08:57 PM
Bowman
09-03-2015 04:17 PM
Quick Reply: 1997 XK8 Code P0153
