1997 xk8 convertible no start issues cam and crank sensor codes
Old 12-20-2014, 06:44 PM
chadbrooks's Avatar
Default 1997 xk8 convertible no start issues cam and crank sensor codes
hey i have a 1997 jaguar xk8 convertible, i have a issue with it not starting have code p1336 for cam sensor and code for crankshaft sensor.. i replaced crankshaft sensor today and still same thing i will be ordering new cam shaft sensor in the morning, it just kills me to see this beautiful car sit. i have a few cars so its not my daily driver but if i can get it going like it was 3 weeks ago i rather be driving my cat then my svt cobra.. pls any help would be appreciated..
p.s. i did have a water leak in my ecu previously to this and replaced the ecu all connections look fine leading to ecu tcm and transmission harness i spent about 9 hours at my shop today tracking down all the wiring to make sure it wasnt a wiring issue.. even tried putting oil down the cylinders to see if it wash a cylinder wash issue but i havent had any luck on my own so i am seeking any knowledge from anyone that can help.
thanks
chad
Old 12-20-2014, 07:04 PM
cjd777's Avatar
Received 1,348 Likes on 744 Posts
Chad, Has the car started since you changed the ECU out. These cars are very funny about matching up numbers on any electrical parts. Are you getting any spark and is the fuel pump running. You sound very well versed on cars, but these cats are a different animal.
Wayne
Old 12-20-2014, 07:13 PM
chadbrooks's Avatar
yea i work on cars for a living and own my own shop.. but when it comes to the cat shes had me stumpped more times than once.lol.. it hasnt started since i put the new ecu in. i started it 3 weeks ago to put it in my impound yard so it wasnt just sitting out in the open and when i went back to it last week battery still held 12 volts turned key to let the system analysis and got a engine fault/ transmission fault took the key out took the 4 bolts off the top of ecu and tcm box took ecu out and a good amount of water came out of ecu come to find out the hose was off to the drain for front windshield, which is the only way i can think that this much water got into the ecu in the 1st place.
i have fuel... havent checked for spark which i should have when i pulled coil packs just put in brand new bosch iridum plugs today. i have a whole xk8 coupe parts car i bought last year because my transmission went bad.
thank you for your time as well
Old 12-20-2014, 07:47 PM
RJ237's Avatar
Received 2,801 Likes on 2,236 Posts
It may be the battery. If it reads less than 12.4 that may be a problem, and if it gets much under 11 while cranking the ECM will not allow power to the coils.
Changing out the ECM for an exact match, including the /xxx code ie LJA1410 AK/010 might work, but still may require a refresh from factory software.
Old 12-20-2014, 07:50 PM
chadbrooks's Avatar
ecu was rebuilt 4/18/14 if that helps any
i have my existing ecu but where the water got on the board is pretty bad tried cleaning it up with electronics cleaner but had no luck? so you think i should try another ecu?
Old 12-20-2014, 07:53 PM
RJ237's Avatar
Another thought. You might want to send your original ECM to ASI and have them test it for $55 or so. Those early ECM's are worth several hundred and shouldn't just be thrown away.
Automotive Scientific Inc. | Quality Rebuilt Automotive Electronics | Rogersville, TN
chadbrooks's Avatar
battery when key is in ignition reads normal when cranking sometimes it goes below 11
Old 12-20-2014, 07:54 PM
chadbrooks's Avatar
i kept it have it sitting on my desk
Old 12-20-2014, 07:59 PM
chadbrooks's Avatar
rj237 orignal ecu is bad had about 1/4 cup of water inside the ecu when i took it out my cat. the board is burnt about 2inx2in on left front side. how much do they rebuild them for?
Old 12-20-2014, 08:00 PM
RJ237's Avatar
Good. If yours can be repaired and the donor car doesn't have traction control I might be interested.
Old 12-20-2014, 08:01 PM
RJ237's Avatar
Ignore that last message, I didn't see your last.
Old 12-20-2014, 08:02 PM
RJ237's Avatar
I doubt if they can rebuild it, but the charge is usually under $400, and the test is included.
Old 12-20-2014, 08:03 PM
chadbrooks's Avatar
i have other parts as well fenders hood throttle body ac compressor powersteering pump bunch of coils 17 inch aftermarket rims with brand new bridgestone tires abs module i have the whole parts car just sitting there. most of the electronic parts are stored in boxes in my shop
Old 12-20-2014, 08:05 PM
chadbrooks's Avatar
the ecu in the car now just sounded too good to be true when i bought it 49.99 free shipping and rebuilt 4/18/14
Old 12-20-2014, 08:07 PM
chadbrooks's Avatar
everything on the board looks good no marks or burns or anything just as clean as can be
Old 12-20-2014, 08:09 PM
chadbrooks's Avatar
what year did they start putting 2 cam sensors in the 4.0 motor?
RJ237's Avatar
OK, back to the battery.
Old 12-20-2014, 08:15 PM
cjd777's Avatar
Did you give it a hard reset. Touching the neg to pos for 30 seconds, with the neg disconnected of course.
Wayne
Old 12-20-2014, 08:17 PM
chadbrooks's Avatar
yes cjd777 and i used my scanner
Old 12-20-2014, 08:21 PM
chadbrooks's Avatar
rj237 what would you like to know about the battery
Quick Reply: 1997 xk8 convertible no start issues cam and crank sensor codes
