1997 xk8 convertible no start issues cam and crank sensor codes
Old 12-20-2014, 08:21 PM
RJ237's Avatar
Received 2,812 Likes on 2,242 Posts
VIN starting 031303 had 2 cam sensors.
Old 12-20-2014, 08:26 PM
chadbrooks's Avatar
reason i ask about the cam sensors is because the ecu is from a 99 xk8 and i have a 97xk8 rj237
Old 12-20-2014, 08:32 PM
RJ237's Avatar
I think I can confidently state that it will not work. That is from a AJ27 engine, you have a AJ26 unless it was replaced.
Old 12-20-2014, 08:34 PM
chadbrooks's Avatar
well theres the issue thank you and i will update with progress do you know anybody selling a ecu for the aj26?
Old 12-20-2014, 08:41 PM
RJ237's Avatar
There are a couple of used ones usually. Do a search for the part # on google, but make sure you get matching numbers like I said earlier, including the last three digits.
Old 12-20-2014, 08:45 PM
RJ237's Avatar
Avoid Central Parts Int'l in Florida. They said they found one and it never appeared. Still waiting for a refund after 5 months.
And forget the battery until you find a ECM.
Old 12-20-2014, 08:49 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
Not all ECU's are compatable with this car and when you find one they need to be programmed to that car.
Gus
www.jagrepair.com
  #28
Old 12-20-2014, 09:17 PM
chadbrooks's Avatar
Gus do you have any for sale or do you know of anyone reputable
Old 12-20-2014, 09:18 PM
chadbrooks's Avatar
i will try and get some pictures of it posted as well its black with black top and tan interior
cjd777 (12-21-2014)
  #30
Old 12-21-2014, 09:28 AM
Gus's Avatar
Gus
Gus is offline
I sell only one item and that is the LSI valve. In the trunk of your car you should find a list of all the modules in that car. See if you can identify and match the code of your bad ECM.
  #31
Old 01-15-2015, 11:06 AM
chadbrooks's Avatar
Default She's alive
Got a new ecu and she cranked right up no issues just wanted to update everybody thank you all for all your help.
RJ237 (01-15-2015)
fast40driver
04-19-2024 07:24 AM
Drew2006
11-24-2015 11:14 AM
1964Daimler
09-02-2015 11:41 PM
201motels
08-30-2015 08:03 PM
rwoodlin
08-29-2015 04:32 PM
Quick Reply: 1997 xk8 convertible no start issues cam and crank sensor codes
