1997 XK8 - convertible top doesn't retract all the time
my middle latch for convertible top doesn't retract all the time. easy fix, or precursor to a green shower? I also would like to know where I can buy a rubber top window seal. while I'm at it.. why would the retractable function of the steering column suddenly quit? do you think I could just pull into a dealer, and get these things fixed, once and for all?
mike mitchell (12-07-2013)
You should check your fluid level, but if your fluid has never been flushed (if it is yellow/brown and not dark green) it needs to be upgraded to Pentosin CHF-11S. The original fluid congeals with age and will eventually stop working. Also make sure the pump petcock is turned fully clockwise.
The seals are a dealer item. Try an online dealer like JPAM parts for a better price, but these seals are still usually around $100 +/-.
The steering column issue could be the switch or motor.
If you do not want to do the work yourself, try to find a qualified Jaguar independent shop...you will usually pay quite a bit less than at the dealer.
+1 on everything WhiteXKR said but a sticky top latch can be something as simple as needing a little shot of spray lube from the outside. If that fixes it you should also check on the green fluid. The yellow stuff is a lot easier to flush before it turns into a paste rather than a liquid.
Here is a good read on the steering column issue: https://www.jaguarforums.com/forum/x...fix-faq-53768/
I had a similar thing on mine...... To the point it would not even release and once did would not go back down. I took the mechanism apart, the oil had turned to sludge and the pump was trying to push it through and couldn't, I dropped it into a bucket of brake cleaner and then blew it out with an air line..... Once put back together, replaced the old oil and now works perfectly
xjrjag
10-27-2021 11:48 PM
