1997 XK8 Engine fan running on.
Once the engine has warmed up the engine fan seems to run very fast and very loud (not vibrating). When I turn the engine off the fan will run on for a few seconds, stop and then come on again for a few more seconds and seems louder than it should. Could this be head gasket issues?
jbfxk8 (06-30-2013)
jbfxk8 (06-30-2013)
jbfxk8 (06-30-2013)
Turns out pump impellor worn almost completely away. Original plastic thermostat has slight leak, has been apart and back together at some stage. Plastic ones never seal again as the plastic deforms (I am told) so new Aluminium housing going on. Chain tensioners very worn. Got it in just in time. Thanks for all the advise.
