1997 XK8 power but no crank, any help please - RESOLVED
Hi everyone,
Looking for some help please! My 1997 XK8 was sitting for 3 weeks in which time the battery died. Had it tested, confirmed dead so replaced it with new.
I've got power but no crank, all dash lights come on and go off as they should. Tried in neutral, park, with brake, without brake and with my foot on the brake really hard! Can unlock with the key and with the fob, red light by the gearstick goes off as normal. Can also hear a relay click below the gearstick when I put my foot in the brake when trying to crank.
I've checked all of the engine bay fuses on passenger side, the small cluster near the windscreen and the larger cluster about half way down the bay. I believe these cover the main potential culprits.
Also swapped the starter motor relay but still nothing.
Tried holding the battery leads together too.
So any ideas please? Having looked through the forums people mention tapping the starter motor and the car not recognizing the key so needs re-programming. Can't seem to find if these suggestions work in the old threads so anyone got any recent findings please?
Haven't tried tapping the starter as I have no idea where to find it!
Any help and suggestions appreciated.
Thanks Rich
Thanks Rich
Look up starter relays in engine bay, the set of relays in the black box in the shape of a T. Try the solution underneath this line first............
But I would bet good money on it being a bad battery connection particularly on the earthing side. Remove all the connectors. Sand them down. Re fix. Bet it starts first time.
Dont forget to let us know how you get on will you? One of my pet hates are those that come onto the forum. Post a help me please but we never hear from them again.
Johnken (02-08-2020)
Check battery connections and then other Earth/grounds
+1 to frankc - check the car first for electrical gremlins.
The connections to your battery may look fine but it’s the ground connection to the body that may need cleaning up. Sand the surface shiney bright and use an electrical contact cleaner not WD40.
The positive cable goes to the HPP junction back behind the spare tyre. This connection can work loose. See pic below.
I had an intermittent start problem like yours and eventually changed my positive cable to a non-crimp solid copper modified cable. Cheap fix.
If that’s not the issue, then I would check the Earth strap on the engine. It’s on the RHS from the bell housing to right wheel well. See pic below.
Not easy to access this one so good luck and, as frankc said, let us know what you find.
Johnken (02-22-2020)
Check out this ongoing thread
Worth checking out this ongoing thread. Lots of good info, and my post #19 has an electrical schematic on all the modules involved in the start.
https://www.jaguarforums.com/forum/x...norway-226005/
You didn’t mention if you have checked the engine earth/ground?
Thanks for replies guys, it's a UK car, I haven't got to the engine ground as yet, its parked in an awkward place against the house which isnt helping!
Thanks for the link to the other thread too, I've had a scan through and looks like a few more things to try, particularly checking the security module.
It can't be jumped, just the same power but no crank.
I'll keep you updated and thanks again.
Just to close this off, the car ending up sitting dead for 18 months.
I had it towed to a local independent Jag guy and it was the immobilizer wasn't recognizing the key transponders so needed reprogramming.
Loads of other stuff required too having sat for so long but all up and running perfectly again now.
Thanks for your suggestions and hopefully someone might find this useful in the future.
jsulliva
11-18-2013 05:00 PM
