1997 xk8 tensioners/gasket kit
I am getting ready to tackle the tensioners. CONFUSED!!! The threads relate info to newer xk8s also read that the Ford tensioners and gasket kit do not fit the 97. Can someone clear the confusion?
Called Advance Auto and National Auto....both say #s that I gave for the Ford parts are not crossing and will not fit a 97 only 99 and up.
Are there Ford #s that work and are they less expensive?
I've got a 1997, so here's some help.
The Ford tensioners and bolts definitely fit your car. I installed mine this summer, with perfect results. Here are your part numbers:
Ford PN 2W9Z6K254BA Right Secondary metal bodied Tensioner (1 required)
Ford PN 2W9Z6K254CA Left Secondary metal bodied Tensioner (1 required)
Ford PN W500301S300 Bolt (4 required - YOU MUST USE THESE NEW, SLIGHTLY SHORTER BOLTS)
I purchased mine from sunroadfordparts.com with great pricing. But any Ford dealer should be able to get them for you. If they question you on the fit, just nod your head and tell them you know what you're doing. If you get the above part numbers, I guarantee you they will fit.
The later cam cover gaskets, however, will NOT fit your car. You need to get the proper gaskets (including the o-rings for the spark plug holes) for your model year. Your jag dealer can get them, or I often order Jag parts from Gaudin Jaguar with great pricing.
Good luck...read everything you can on this forum...it's all here.
Stan Clark (05-05-2012)
