1997 XK8 Transmission fill plug
would you know the hex size to make sure im getting the right one? also right side meaning passenger side..
motorcarman (05-19-2017)
Many have talked about changing the transmission fluid which is a real good idea. I found that rather than using a combination of tools to get the fill plug out, it works real well to buy a piece of 1/8" X 1" of strap iron (use a foot long piece) and an 8 mm allen wrench. Cut a piece off, about 7/8") the end of the wrench, drill a whole in the end of the strap iron and weld the piece in the whole. This enables you to get the fill plug out with minimal chance of striping it and putting it back in with burning yourself. This is the same as the tool Jaguar has in there shop and costs less than $5 to make and very well work it.
Good Luck
Bob
Good Luck
Bob
