1997 XK8 transmission valve body repair
I have a 1997 XK8 that is slow to engage drive after backing up. It takes around 4 seconds to engage . From what I have read here that is a symptom of pressure regulator valve wear in the valve body, which in turn will take out the A drum. I found the Sonnax kit with reamer and oversized valve. Has anyone used this product and had good luck? Or is somewhere I can send the valve body to have it repaired? The transmission operates normal after the slow initial engagement.
Thanks for your time.
shawn45 (07-24-2024)
RoyLittle0
05-25-2023 02:38 AM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
