1998 can't find low pressure port to recharge air conditioner
Today I found that I get no cold air from a.c.. I tried to find the low pressure port to recharge it, but no luck. One older post indicated it is be air cleaner and radiator, see photo, but there is no port evident.
If memory serves it is near the firewall passenger side. Be careful. If you overcharge system you will create a nightmare. I suggest an evac and recharge at a qualified a/c shop.
if you decide to chance it do not use the gas that has sealer or oil in it. Sealer will screw the system, and an excessive oil charge will not allow proper heat exchange or worse damage the valve plate in the compressor.
good luck
Thanks Denny, I'm going to just put some refrigerant in if I can find the port. Tried Gus excellent site and couldn't find anything there either.
BTW, no one has discussed the need to short the connection to the low pressure switch in any write up I've seen. Back on my 1980/1990 Ford's, and GM cars this was critical. Premise being - you lost refrigerant, always trips the low pressure switch preventing compressor from running, you'd stand no Chance of getting more R134 in unless you could get the system to run allowing system to accept more of the gas. So that's why you shorted the switch connection (it goes open when pressure too low) to allow introduction of more refrigerant. May I assume this is N/A (not applicable) to X100s?
I have completely evacuated the system on my 99XK8. You don't need to short or bypass anything to refill the sysyem. How do you know you are low on freon, it could be other things causing the AC not to work. If you are actually low on freon you have a leak somewhere and that should be addressed first. Most systems have a green fluorescent dye that will help you pinpoint the leak.
I agree with Denny that the system should be completely evacuated with a vacuum pump and then refilled with the proper amount of freon.
This is the port you are looking for. It is between the air duct and firewall on right side, passenger side, of the car.
The a/c system on this car is not an orfice tube system like on the old ford and gm vehicles. This is an expansion valve system. If you start shorting switches in this ststem
you will cause damage to the transducers that control the compressor, fan operation etc. There are several sensors in this system that can be damaged with improper technique.
If you located a leak in the condenser you will have to replace it. No sealant please.
Thanks guys. I've always been taught that all a.c. systems loose some refrigerant slowly year after year. Guess I figured since mines never been touched in 19 years that's the issue.
Well I'll scope out prices to hire someone to do as you suggest.
