1998 jaguar xk8 lights stay on
Since it will shut off the headlights and not the remaining lights, I would think you have a loose or shorted wire in the Stalk multi switch. The norm for a loose wire would be intermittent operation or none. It is possible that one of the wires is creating a ground causing the lights to stay lit.
I would remove the covers on the steering column and start checkiing the connections to the stalk. The stalk is the only point that i think all of the other wires come together.
If the wires don't seem to be causing a problem them I would replace the stalk switch.
Received 2,387 Likes
So, if I understand your symptoms, when you remove the key, irrespective of where the lighting stalk is set, the sidelights & side marker lights remain on?
In which case, you must have to keep putting the battery on charge?
Is this correct?
Mike
Is this correct?
Mike
01-22-2007 12:38 AM
