1998 o/s front lower ball joint dust cover split
Hello my 1998 xk8 failed her mot on 2 things ,,,wish bone front bush and lower ball joint boot split,,,,,do I have to dismantle things to lift ball joint out and replace rubber boot (the ball joint itself is fine)can I just unbolt split joint with ball joint splitter and jack it up replace boot,thanks all
Received 4,340 Likes
thankyou ,,,,,I did manage to get the long bolt out eventually....lots of banging wd40 and a very long bar and it worked loose,,,,I must admit I nearly gave up,,I did a video of it and put it on you tube under my name
KarimPA
09-12-2015 08:15 AM
