1998 XK8 Key Slot Question
Old 07-07-2021 | 11:39 AM
XK8 Comfort's Avatar
Default 1998 XK8 Key Slot Question
I am trying to pin down what I think is a problem with my vehicle battery. I replaced my battery with a new H8 AGM battery and have connected a Genius G3500 charger to make sure it is fully charged. It went through the steps to where the Green charge indicator is flashing and has not yet showed a solid Green indicator indicating full charge. Everything functions normally on the vehicle but I am concerned I might have parasitic drain. I checked the ignition key slot and it appears the "door" in the key slot is in the proper position. (See attached photo) To my knowledge the silver tab in the center of the ignition switch is as it should be. The key inserts
normally and pushes the door in and starts normally. Would like to get confirmation since I have read quite a bit about the "door".
Old 07-07-2021 | 11:58 AM
Jon89's Avatar
Looks very similar to our 2006 XK8 key cylinder. For good measure I would lube it with a small amount of graphite powder. Good idea to do that several times per year to keep that key door working properly...
Jon89
07-22-2020 10:26 PM
dinop
01-17-2016 07:55 AM
earlyred
02-23-2015 11:46 AM
mbelanger
07-16-2014 11:07 PM
RJ237
08-14-2012 01:56 PM
Quick Reply: 1998 XK8 Key Slot Question
