1998 XK8 low air flow from vents
My 1998 XK8 has very low air flow from all of the vents. It sounds like the fan is blowing hard, but very weak flow. Pushing the various flow selection buttons and recirc button sometimes seems to have some very small effect, but not much. The air that comes out seems to be the called for temperature, hot or cold, just not much of it. I am having a hard time finding any information on how the ducts are laid out and function with the various selection options. Any information or guidance would be appreciated. It would be nice to get out of the car on a summer day without dripping sweat.
kstevusa (07-05-2022)
I can find information on the RH fan, but very little on the LH fan. I think I can see it but don't have anything disassembled at the moment. I ran the actuator check by holding the Auto and Recirc buttons while turning on the ignition and none of the displays indicated a problem. I could hear actuators cycling through their tests, but don't know if they were actually working correctly. Also the error code only showed 23 which says it could be caused by cold weather. It was cold enough last winter to set the code. I cleared it and it didn't come back. Having done that, when the fan speed is on high the vents now blow at what I would consider to be a medium low speed airflow, but at least it is something and much better than it was. It would be nice to know what changed by running the diagnostics. As long as I get some airflow I'm inclined to let it ride for now. My experience is 24 year old plastic pieces tend to be brittle and break easily taking things apart and putting them back together. I've replaced some parts behind the dash, the starter, water pump, and power steering pump so I'm not afraid to tackle it if I have to, but may hold off for now.
Thanks for the response. I didn't know it had two cabin fans.
Tip for this: each fan has its own fuse. Disconnect these fuses in turn to figure out which fan (or both) still work.
Other tip is to go and pop the center (face?) trim, then remove a couple of screws to remove the vent. Once the face flap is open, there is a (mirror-assisted) view of the heater core and A/C evap.
eBay sellers for these used parts sometimes post great pictures. Worth a look.
Best of luck, keep us posted.
The following 2 users liked this post by fmertz:
motorcarman (07-05-2022),
zray (07-10-2022)
I found the drivers side blower is not working. The recirc door will open and close and air blows out of it from the passenger side fan when it is running as I was told it would. The fuses are good. I found another thread that said the blower relays are tucked above the plastic floor vent somewhere. No luck finding them yet on a quick look. I'm gathering wiring diagrams etc to get more serious about the troubleshooting. From the diagrams I have it looks like the power transistor is inside the blower assy. I can't find any information on how to remove the driver side (LH) blower assy. I have the lower bolster and a metal cross member removed so I can see the bottom of the assy and what looks like a couple of bolts at the top front, but no idea at this point what else is involved in getting it out. I did see a couple of blowers on EBay.
Good news and bad news. Good news, the motor isn't bad. The bad news, I found a problem with the wire from the 20 A blower motor fuse to the blower motor relay socket. Both sides of the fuse have 12V, the relay base has 0 V. I jumpered power from the RH to the LH relay socket and the LH fan ran. The diagrams I have show the wire coming out of the fuse panel connector FC6-2 to connector AC16-3 to the relay socket. So far I have not identified FC6 or located AC16. The manual location for AC16 says "left hand A post connector mounting bracket / A post trim" I can't find any information on removing the fuse panel or the trim piece surrounding it. Any info would be great. I will keep contorting under the dash in the meantime trying to track the wire.
I located connector AC16 that the power wire runs through mounted in front of the hood release lever. With the connector apart the section of wire from the fuse block to the connector checked OK, and the section of wire from the connector to the relay base checked OK, but when the connector was plugged back together there was high resistance from the fuse to the relay base. I could not extract the pin or the socket from the connector so I tried cleaning them the best I could with no help. I found tugging and pushing on the wires would on rare occasion complete continuity, but only long enough to blip my meter reading. I finally cut the wires on both side of the connector and crimped them to an insulated spade mating pair to reconnect the wires. The fan now runs. The mounting clips have a dimple that engages a lip on whatever mounts to them so it makes it a little harder to remove things from the clips. I tried a small screw driver in the slot in front of the clip to see if it would disengage, but not much help. I think just pulling harder finally removed them from the clips. Location pictures below.
TedV (07-09-2022)
