1998 XK8 with a P1396 Trouble Code
I'm hoping to find some assistance with a persistent P1396 Trouble Code.
I know it's a problem with the left bank VVT and so far I have changed the oil and filter, checked operation of the solenoid and the wiring and connector.
I also checked the camshaft position reluctor on the rear of the cam and it's aligned properly. I would like some help finding out more about the "o" rings.
I see the large one that seals the body of the solenoid when it's installed on the opening but I don't see an other "o" rings. Does anyone have an exploded view that shows the "o" rings and their position, or any other suggestions? The car runs great, but I can clear the code and if I don't let the engine warn up for a minute or two, the light comes back on after I take off and drive a couple hundred feet. If I do let it warm up the light will not come on, and I can drive all day with no CEL.
Thanks very much,
Dave B.
Thanks very much,
Dave B.
There are seals on the oil inlet to the intake cam helical unit. They are a split overlap type seal but the front cover must be removed to access the parts.
I think there are 'O'rings from the head to that oil transfer unit that supplies oil to the intake cam helical adjuster.
The only other 'O'rings are the VVT actuator seals.
I assume you read TSB 303-08 for the reluctor alignment.
You might try a thicker or thinner oil viscosity or a different type or brand of oil to see if anything changes???? Maybe a different oil filter brand????
I had a VVT DTC on one of my AJ27 XJ8s so I put 10W40 synthetic for the Summer and it cured the fault. The other XJ8 is happy with 5W30 all year.
bob gauff
bob gauff
Burdedw (11-14-2013)
I wanted to do a follow-up to my P1396 Trouble Code.
I checked and double checked the wiring and connector to the VVT Solenoid (left bank)
I also checked the Reluctor position on the rear of the cam.
All was well.
I decided to change back to 5W 30W Castrol Edge full synthetic and switch from a Fram to a Purolator PL15317 Oil Filter.
(I had gone to 10W-40W because of the high milage on the car)
The result is, no more CEL at any time.
I'm a happy guy!
Thank you Motorcarman for your excellent suggestions.
Dave B.
All was well.
I'm a happy guy!
Dave B.
