1998 XK8 Power steering problem
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I just took delivery on a second XK8. I think I have lost my mind but I guess I can't help myself. The good news is, I get to know you guys better. So far this has been a great experience.
About the power steering issue: When I took delivery from the shipper this cat was hard to steer (no power steering). When I parked it in my garage the next day I found a nice big pool of power steering fluid on the floor. So yesterday I filled it with fluid and worked the wheel back and forth to try bleed the system. It is very noisy and when I shut it off power steering fluid bleed out the breather hole on the cap. I think that is where the original pool came from. Is there a check valve in the system that may be stuck or something. I also notice the passenger side boot on the rack is now leaking form what looks like pressure forcing it out of the seal at the tie rod end. Any advice on how to diagnose this and resolve the no power steering problem is greatly appreciated. Thank you in advance. Great forum!
Jeff
Jeff
It sound like you have air in the system and the rack boot should not leak fluid.
The JTIS bleeding procedure is:
1. fill reservoir with fluid to bottom of filler neck and wait for air to escape - when air bubbles are no longer present.
2. top-up fluid to bottom of filler neck if necessary.
3. raise front of vehicle and support on stands.
4. do not start engine, turn steering from lock-to-lock three times.
5. start the engine. Immediately top up with fluid as air is expelled.
6. turn the steering lock-to-lock three times.
7. switch engine off.
8. lower vehicle.
9. top-up fluid level to maximum mark on dip-stick.
10. fit reservoir filler cap.
8. lower vehicle.
Graham - Thanks for the speedy reply. Problem is: I already did it the wrong way per my original post. I think what I will do is try your method with the fluid that is in there. It sat over night so hopefully I can sort it out. Thanks again. Next time I will be sure to go here first before forging ahead.
regards,
Jeff
regards,
Jeff
If you are losing power steering fluid then by definition you have a leak, which from your description sounds like it is coming from the hydraulic seal on the end of the rack - you need to get the rack rebuilt which will include new seals throughout. Don't run the car without fluid in the system - power steering pumps do not like being run dry- high risk of further damage.Have a look at the fluid which is in there at the moment - if it shows traces of fine metal filings chances are the pump is damaged. If you run a new or rebuilt rack with contamination in the system it may well fail again.
Bluexk8ragtop provided this info when he was repairing his car. Maybe it will be of use:
Steering Rack Seal Kit - XK13574 | Jaguar XK8 - XKR | Jaguar | British Parts UK
Thanks for all the input here. I read some different threads and it looks like rebuilding a rack can be hit or miss depending on the condition of the sealing surfaces and access to tooling to resurface them. Would a safer bet be to replace the rack with a rebuilt unit from the guys that know what they are doing? Does any one have a recommended vendor for a rebuilt steering rack? Thanks again.
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
I had the same problem with fluid leaking from the boots, I took a gamble on a cheap second hand unit which cost about £70 and swapped them over.
See here https://www.jaguarforums.com/forum/x...-video-117243/
