1999 XK8 4.0 bogging down issue
Hi All
I would appreciate any help/pointers or advice on this problem which started 18 months or so ago, but the car has been parked up since then due to other maintenance issues (rust protection etc), but note the problem started before being left unused.
Engine starts and idles ok.
From cold or war/hot you can press the accelerator or manually operate the throttle on the side of the throttle body and half the time it noticeably bogs down, sometimes nears a stall.
It actually drives a short distance (1 mile or so) without any issues, but seems down on power.
We have also now noticed that just as you open the throttle there is a sound of air rushing through the intake manifold before it actually revs. That seems new, never noticed it before ever.
Since deciding to re-commission the car, we have done the following (note again problem started before addressing these):
Checked Butterfly is opening when expected, and seems ok.
Yet to check the fuel filter but I do not see how that could cause this.
The fuel pump is running, although very quiet, possibly the original.
Fuel pressure at the rail seems low. Pressing the valve we only get it to squirt vertically about 2-3 inches which seems maybe low?
Not cleaned the throttle body yet. I see the way Gus cleaned his here JagRepair.com - Jaguar Repair Information Resource
or is it best with a manual clean also to get to the underside of the butterfly?
Any thoughts?
The new noise of air intake through the manifold seems quite odd and key to the problem.
Thanks in advance.
James
- Oil and filter change.
- New NGK iridium plugs.
- New E5 fuel - Esso 99.
- New air filter.
- Cleaned MAF with a quality MAF cleaner.
- Cleaned MAF connections with an electrical cleaner,
- Checked the main intake duct and the smaller breather for leaks (does not seem to be any holes/splits visible).
- Double check/top up coolant.
Any thoughts?
Thanks in advance.
James
Hi All
Any thoughts?
Thanks in advance.
James
- New air filter.
Any thoughts?
Thanks in advance.
James
A simple yet effective way to test for leaks at intake or manifold or air mass sensor is as follows: start the car; while idling, spray carb cleaner, lightly at any point of a connection or a gasket, choosing one spot at a time and waiting before spraying again. If you spray an area and the idle increases, there is more than likely an air leak in that spot. Spraying the cleaner, will introduced alcohol into the air flow and thereby increasing the idle briefly, confirming an air leak.
markmywords (07-22-2023)
Moving to the pump now, but the fuel pressure from a visible observation at the shrader valve is no different than our XJ8 Probably not the pump either then.
Received 2,400 Likes
I hope this one works. The intake noise is not as loud on this, but you can hear it. If you rev gently the engine behaves. If you suddenly rev it (not WOT just a little) the revs dip quite a lot.
No codes at all which is a shame.
Just a long shot
I read on this forum of cars having air leaks in the intake tube. There seems to be leaks in the "accordian" section of the tube. Perhaps the information from the MAF is causing the ECU to send in to rich of a mixture caused by the air leak in the intake tube?
I hear the injectors ticking, then the dip when you press the throttle, but the noise when the motor catches sounds to me more like a chain thrashing or similar. Maybe that's just the acoustics on my laptop and I can't be certain.
Are you sure the noise is coming from the intake? Can you pin it down further:- back/front & top/bottom of the engine?
Does it sound happy if you hold at, say, 2000 or so rpm? Bear in mind the rpm limiter kicks in at around 3000 and causes the engine to run roughly.
Anyone?
Anyone?
Anyone?
Anyone?
It is hard to hear any air intake noise on that recording, but it seems to be coming from the top of the engine around the inlet manifold. It is like it gasps for a split second before revs.
The VVTs sound and feel noisy (more on one side) when under a sudden/abrupt rev as if it has not engaged in time.
Also, holding the throttle open at say 2K, it is fine, nothing strange until you do another abrupt rev higher (not much higher), then it does the same and gasps and drops revs a split second.
Luckily all the parts we have substituted on this we have had as spares from my old XJ8, but we do not have any VVT solenoids. It may be worth taking them out for a clean, but there is a chance we know somebody that has a couple to borrow.
Failing this, kinda stuck as to what is causing the problem.
Thanks for your replies and assistance.
You can definitely hear the VVTs, and touching the top of the plug you can feel them too. More one side than the other when the throttle suddenly opens. Gradually increase the revs they are quiet, which from what i read is fairly normal.
Quick update.
Following TSB 303-47.
Page 6 and starting P17.
Pressure should be 38 PSI + or - 5.
Fuel pressure is 35 PSI at idle, on a sudden rev (as per when the symptom occurs) it rises and peaks at maybe 40, then drops right back down above 30-32 then back to 35 after.
I think that eliminates the fuel pump and line.
What I would try
Quick update.
Parker 7 (02-15-2024)
