1999 XK8- Battery Draining- BPM or lamps suspect
The battery on my XK8 has been draining intermittently during the past few months, and for the last two weeks it has been draining regularly after 2 or 3 days of sitting.
After fully charging the battery, I used a multimeter and pulled each of the fuses to check for drain, which is fairly consistent at .2 amps. However, the drain ceases when the Body Processor Module (5V logic and lamps), fuse 5 on the Fascia Fusebox, Driver's side, is pulled out.
Does anyone have a suggestion on how to proceed? I am guessing that it may be a bulb or connection, but I am not certain which bulbs are on this circuit. From what I have read on the forum, if a bulb isn't to blame, it's time to take it in for a pro to find a BPM or 5V logic circuit issue.
Any help would be greatly appreciated.
Thanks and have a great time driving this spring!
Guy-Pierre Boucher
09-16-2015 06:55 PM
al_roethlisberger
09-07-2015 11:53 PM
