1999 XK8 Bolt torque on 4 throttle bolts
Here are some of the torque values
1999 XK RANGE - Engine - 303-01
Description Nm
Accessory drive belt tensioner 38-48 - -
Accessory drive belt idler pulley 53-69 - -
Air intake tube to throttle body 4-5 - -
A/C pipes to receiver / drier 8-10 - -
A/C pipe manifold joints 8-10 - -
Camshaft bearing caps 9-11 - -
Camshaft cover 9-11 - -
Charge Air Cooler Adaptor to cylinder head (SC) 20-22 - -
Crankshaft damper bolt - no locking ring 80 + 80° - -
Crankshaft damper bolt - with locking ring 364-386 - -
Crankshaft position sensor 8-12 - -
Cylinder head bolts M10 35 - -
Cylinder head bolts M8 (two at front of head) 23-27 - -
Driveshaft (propshaft) drive flange bolts 75-88 - -
ERG pipe to exhaust manifold 18-24 - -
Engine compartment cover (bonnet) hinges 22-28 - -
Engine coolant radiator top securing panel 22-28 - -
Engine front mounting 60-80 - -
Engine oil cooler pipes (clamp) 18-24 - -
Engine / Transmission assembly rear mounting centre bolt 30-40 - -
Engine / Transmission assembly rear mounting outer bolts 22-28 - -
Exhaust downpipe support bracket to flywheel housing 43-57 - -
Exhaust downpipe to lower mounting bracket 42-54 - -
Exhaust camshaft sprocket 115-125 - -
Exhaust manifold to cylinder head 16-20 - -
Exhaust manifold flange to downpipe 15-20 - -
Exhaust Torca clamps 50-60 - -
Fuel cross-over elbow 8-12 - -
Fuel feed pipe to intake manifold 8-12 - -
Fuel injector harness clips to camshaft cover (SC) 4-5 - -
Fuel pressure regulator to intake manifold 8-12 - -
Fuel rail to Charge Air Cooler Adaptor (SC) 18-24 - -
Intake manifold to cylinder heads 20-22 - -
Intake elbow support brackets 16-20 - -
Oil filter 15-18 - -
Oil Cooler 7 - -
PAS pump hose unions 22-28 - -
Primary timing chain fixed guide 10-14 - -
Primary timing chain tensioner 10-14 - -
Primary timing chain tensioner blade 12-16 - -
Secondary timing chain tensioner to cylinder 10-14 - -
Steering rack 40-50 - -
Throttle body to intake elbow 18-24 - -
Throttle cable abutment to throttle body 4-6 - -
Throttle intake elbow to intake manifold 18-24 - -
Timing cover 11-13 - -
Variable camshaft timing oil control unit to intake camshaft 40 + 90° - -
Variable camshaft timing oil control unit housing (bolt and nut) 19-23 - -
Variable camshaft timing oil control solenoid 10-14 - -
Water pump pulley 10-14 - -
Description Nm
Oil Cooler 7 - -
reb1999 (05-07-2016)
FS[NorthWest]: XK8 / XKR Polished Aluminum J-Gate Shifter Surround Bezel
xjrjag
05-02-2016 10:32 PM
