1999 XK8 carpet set
They used stock, it does not have to be molded. Any good shop can put it in and it should look perfect. I did not go crazy on the carpet, you can spend tons for real wool, I just picked a black carpet from the shop that I liked. It was $600 for the carpet installed. They had my seats off anyway so they cut me a little break.
Rezzz (07-24-2014)
Any reputable auto interiors & tops shop can do this with the carpet and padding of your choice. You'll save considerable money using their available selection vs. ordering factory pieces from Jaguar. Plus, you'll have a much wider array of choices and you'll usually get a better, longer-lasting carpet if you do your research before you make your final decision....
Rezzz (07-24-2014)
