1999 XK8 conv hydraulic cylinder
Just purchased a 99 XK8 convertible that needs the hydraulic cylinders replaced.
My mechanic tells me he is having trouble accessing them due to their location between two metal plates.
Any ideas or suggestions??
Thank you.....Jim.
Thank you.....Jim.
Hi Jim,
Suggestion would be get a new mechanic.. Or, be slightly more generous and direct him toward all the helpful threads here. It really is not hard to get at the cylinders; plenty of stuff needs removal, but it is quite straightforward. Just do a search and you will find step-by-step.
Lars
Lars
agree with Lars - plenty of threads here on how to access - remove the rear seat back and cushion, then remove the side panels and you can see the cylinders.
Follow one of the links below:
https://www.jaguarforums.com/forum/x...-problem-5663/
JagRepair.com - Jaguar Repair Information Resource
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
