1999 XK8 Convertible drivers door stuck
I just went to get out of my 1999 XK8 convertible and the drivers door only opened half way. It closed correctly but from outside handle or inside pull handle the door would not open all the way. I tried many times with my son but I don't want to break it. Anyone have the same problem with a fix? I had to climb over the center console to get out the passengers side. I am 64 with a bum back. Help!
Jack
Jack
[QUOTE=xkeots;1525829]I just went to get out of my 1999 XK8 convertible and the drivers door only opened half way. It closed correctly but from outside handle or inside pull handle the door would not open all the way. I tried many times with my son but I don't want to break it. Anyone have the same problem with a fix? I had to climb over the center console to get out the passengers side. I am 64 with a bum back. Help! The passengers door is fine.
Jack
Jack
Jack
Matthew. Keep I mind that you have one of the cars that has the least number of known problems. No tensioners, no plastic thermostat covers, and the 6 speed transmission. There are an average of 500 people on this board at any time. We see an average of 1 or 2 new or weird problems a week. If yours breaks, there is a great chance that the problem has already been seen, diagnosed, and fixed. You want scary, go to a Mercedes site and look at the problems they have with their 10 year old cars.
Matthew Chidester (08-30-2016)
Thanks Rick
yeah.. I've read some users who have written reviews on car sites before my purchase that loved the car and are lifetime Jaguar owners.. zero problems and then I surf this site because I'm into my car so much and HOLY :O
anyway I have to keep telling myself.. preventative maintenance preventative maintenance.. but thanks I'll try to relax!
(and sorry to hijack the thread! Hopefully you figure out the door locking actuator/striker issue)
Jack
1999 XK8
Thanks Jack, much better description. A few more questions to help get you an answer.
Can you get it all the way open at all ? I'm sure you will need access to either the lock mechanism or inside door.
Do the door locks cycle at all (on off on off) ?
Does alarm work normally ?
Does it matter which handle you use inside or outside ?
First let's clear up if you have a door that can not be opened are all or not.
If it can be opened, please describe what you have to go through to get there.
John
Let us know
John
Let us know
Thanks all and any other thoughts are gladly accepted
Jack
1999 XK8
[QUOTE=xkeots;1526890]Weird thing is this. After 2 days of climbing over center console the door opened. I blasted locking mechanism with wd40 and lithium grease. Now it's like normal. I wish I knew what caused it so I can take door panel off since door opens and check mechanism.
Jack
1999 XK8
PS: It feels good having oldest daily car in area (that I have seen)
Jack
1999 XK8
Jack
Jack
Is the glass in the Driver's Door Auto-Dropping the ~1.5"'s, or so needed to clear the Convertible Top Frame? If not, the door's glass will be stuck up in the frame it retracts into when fully closed and sealed and prevent the door from opening or closing completely. I had to find out the hard way how to thread the window back into the top seal of the door frame with no power, and a fully rolled up window, to be able to close the door. It can be done, it just looks and feels like you are going to break the window off when opening the door; closing the door, for me anyway, is much easier than opening the door, when this occurs.
If it is the Door Latch Micro-Switch starting to fail, you can expect to see more of this until the window will no longer drop at all, and the door lock may start to malfunction as well cycling off and on, leading to problems setting the vehicle alarm and locking or unlocking the door. The cure for now, is what you have already done, by spraying the WD-40 into the door latch, and lubricating the latch mechanism.
The same thing happened to me but it was both doors. I have a 99 xk8 covertible also. What i did was start it up (i know this sounds weird)....and put the convertible top all the way down and up again and it seemed to fix the whole door issue. It was like my xoors werent lining up with tbe body. It was weird. Just a thought....
John
Let us know
John
Let us know
Will see next trip. I am going to see my friend who is a tech manager at a local Jaguar dealership about this issue.
Jack
1999 XK8
dsnyder586
03-30-2016 09:47 AM
