1999 XK8 convertible top woes
Hello,
I have a 1999 XK8, which I bought in 2008. In 2009, I had a hydraulic leak at the dome light, and had to replace the lines from the pump all through the car.
The top has operated fine until recently, when I started to have problems again. The pump reservoir is filled to the line. When I push the button to lower the top, the rear windows go down, but nothing happens. I can hear the pump working.
The bell doesn't ring. I really love this car. Help!!!!
The first thing to do is verify that the 'T' handled valve on the side of the pump housing is fully closed clockwise. If open the pump will run all day without anything else happening.
The second item if to verify that the fluid level is correct in the pump reservoir. You might have to get upside and backwards with a flashlight to verify that. Anywhere between the two marked lines.
With those items check let us know what happened.
I checked the "t" and it was tight. The fluid level was fine. We did a hard reset by disconnecting the battery. It worked better after that, but is still not consistently operating smoothly. I can't see any leaks on the ground, but there are drips of fluid coming from the domelight... any thoughts?
Received 6,332 Likes
Johnken (10-11-2016)
I was dropping the top today and took a shower from hydraulic flood coming from the center around the courtesy lights and mirror area. Now my back windows are down and I can't latch my top. Any idea how to manually latch te top and get the back windows up? Any help would be appreciated on this matter.
